حسن هاشم
2024-11-30 16:57
When making a turn with the 2021 model, there's an unusual noise from the front wheels. It doesn't happen during normal driving. What could be the issue?
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
Is it normal for the 2021 four-wheel drive to show an icon on the dashboard with the front wheels tilted, or is it a four-wheel drive warning? The dealer says it's normal, but it didn't seem to be there before. 🤦‍♂️
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Hello fellow car enthusiasts, my car makes a thumping noise from the right front wheel when I turn left. Does anyone know the reason for this?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
Hey, fellow car owners! Have any of you experienced a loud creaking noise coming from the chassis when turning the steering wheel while stationary? I'm not sure if this is normal or if it's an unusual noise, but it's really loud and quite bothersome 😫
What causes the steering wheel to make a noise when turning the shaft?
