The PRND lights next to the gear lever are not lighting up, what's going on?
Hey folks, I have a question. My car can't shift gears. When the engine is off, the gear lever can move freely, but when the car is on, it's like something is blocking it, and it won't go into gear. It's a manual transmission, and I can't shift into any gear from 1 to 5 when the car is on. Does anyone know what the problem might be? Thanks 🙏🙏🙏🙏
Does anyone know where to replace an electronic gear lever?
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
4Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
5Does anyone know what the W button next to the gear lever on the 2019 automatic model is for?
6What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
7This morning I noticed that there are only 7 gears in manual mode, what's going on?
8What's going on with the 2014 Peugeot 308 dashboard warning light?
9Why is the plastic near the gear lever on the passenger side very hot?
10I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
