The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
Even after changing the middle exhaust pipe, the fault light is still on. What could be the reason?
What could be the reason that the MG ZS won't start with the push button?
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
4Engine shows fault code, acceleration is weak, what could be the reason?
5The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
6The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
7What could be the reasons when the vehicle displays "no key" and won't start?
8When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
9The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
10The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
