Is the transmission oil filter of the 2021 Santana Automatic Fashion Edition made of steel mesh or paper? Does anyone know? Can the transmission oil be changed without removing the oil pan?
How to insert a USB drive in a 2018 Mitsubishi ASX manual transmission fashion edition?
Do I need to remove the oil pan to change the oil?
For the 2021 Santana Automatic Comfort Edition 1.5L, how many kilometers should it be before changing the transmission oil?
4Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
5Does a 2021 car with 55,000 kilometers need a transmission oil change? 😊
6Does the 2021 Santana come with a particulate filter?
7Hi everyone, could someone help me out? Where is the external transmission oil filter on the Acura TL? I'm getting my transmission oil changed, and the mechanic said this car doesn't have an external filter.
8Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
9Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
10For a 2021 Santana Automatic Fashion Edition 1.5L, how many kilometers should you drive before changing the transmission oil?
