I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
Waiting at a traffic light, slow start, have to press the accelerator [angry]
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
My car is automatic, and I recently noticed that when I start on an uphill, there's a kind of "bo bo" sound when I press the gas. It seems like it's coming from the transmission. But when I'm driving normally, there's no problem. Even when I hit the gas hard or drive on the highway, it's fine. It's just when I start on an uphill. 😂
4I recently got a 2013 model 2014 Scirocco GTS. Why does the car start shaking and not move when I floor the gas pedal to start?
5The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
6The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
7Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
8I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
9Even with the clutch fully pressed, the car still won't start.
10Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
