I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
408 Accent, ABS and brake lights are on. But the car seems fine. What could be the problem?
5The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
6Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
7Has anyone experienced this situation? (The lights flicker while driving, the battery is fine, it's not the automatic headlights, and it doesn't happen very often. A roadside repair shop moved the headlight's fuse, but the problem still hasn't been solved.)
8What could be the issue if the ABS warning light is on in a 2013 Santana 1.4 manual?
9I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
10I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
