علي نادر
2024-02-26 20:35
How often should the timing belt and accessory belt be replaced on your Santana?
Comments( 8 )
عمر مساعد
عمر مساعد2024-07-28 14:52
126,000 km and still haven't replaced it?
فهد جمال
فهد جمال2024-07-20 11:34
If you drive 10,000 kilometers a year, can the car be used until it's scrapped?
علي حميد
علي حميد2024-07-19 22:54
When getting maintenance done, have the mechanic check the car thoroughly. You don't have to worry about it yourself. 😄
محمد فهد
محمد فهد2024-03-01 14:31
I've driven 110,000 kilometers so far, and at 80,000 kilometers, I did a major maintenance. I haven't replaced anything else.
حسين شعيب
حسين شعيب2024-02-28 12:07
My 10-year, 150,000 km one was replaced, and it looked just like new when taken out.
عبدالله عادل
عبدالله عادل2024-02-27 18:26
Driving for 150,000 kilometers should be fine, even though the manual says to replace it at 90,000 kilometers.
عبدالله عادل
عبدالله عادل2024-02-27 18:25
I changed it after a little over 100,000 kilometers... However, after taking it apart, the belt showed no wear. The repair shop said there was no need to replace it... But since it was already dismantled, I went ahead and changed it... The timing belt itself isn't expensive; the labor cost is what's pricey...
حسن حسين
حسن حسين2024-02-26 21:22
It's been the sixth year this year, and I've driven 115,000 kilometers. Apart from a wiper, I haven't replaced anything else.
