How many kilometers before the timing belt of the Volkswagen Santana needs to be replaced?
How many kilometers should the Kia Pegas drive before changing the belt?
How many kilometers should the timing belt of the V97 be replaced?
For the 2021 Santana Automatic Comfort Edition 1.5L, how many kilometers should it be before changing the transmission oil?
4How often should the timing belt and accessory belt be replaced on your Santana?
5For a 2016 model, does it need a timing belt replacement? At how many kilometers should it be changed? Also, when driving on rough roads, there seems to be a "thud" sound from the suspension. It has just reached 80,000 kilometers now.
6How many kilometers does the timing chain of a 380 need to be replaced?
7How often should the timing belt be replaced? My car is over 9 years old with 81,000 kilometers on it. Do I need to replace the timing belt? Thanks to all the fellow car enthusiasts.
8How many kilometers before the timing belt of the Volkswagen Santana needs to be replaced?
9Hey everyone, at how many kilometers should the timing belt be replaced? I've run 94,000 km now.
10How many kilometers do you guys usually change the timing belt?
