Hey guys, my Santana doesn't have a sunroof, but I found water in the trunk after it rained. What's going on?
What should I do if the trunk of my 1.6 automatic car has water ingress? Is it a big issue?
Hey guys, after replacing the sunroof glass on the V40, is it still leaking?
Hi everyone, has anyone experienced water seeping into the back seat after heavy rain? I can't find the cause, and there are no signs of leakage.
4Hey guys, my car got hit by AC water droplets, can't scrape it off or wash it away. What can I use to remove it?
5Hey guys, do you hear the sound of water sloshing in the tank when your Y shakes?
6My sunroof won't open, what's going on? I press the button, but there's no response at all.
7Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
8Hey guys, does anyone know why the trunk can be opened with the key but not by pressing the button?
9What's going on with the Skoda Kodiaq A-pillar leaking water when it rains?
10Hey guys, my Santana doesn't have a sunroof, but I found water in the trunk after it rained. What's going on?
