خالد تاج الدين
2024-01-06 15:45
Hey folks, how long did you wait before hitting the highway? I've actually been driving for less than two months, or maybe two years. The car's been sitting back home and I'm worried it'll just go bad. Any advice from those with experience? Much appreciated 🙏🙏🙏
عمر مساعد
عمر مساعد2024-08-09 14:06
Keeping the car running can prevent it from breaking down.
2
علي حميد
علي حميد2024-07-19 23:10
My suggestion for beginners is to frequently drive on national roads, multi-ring roads, expressways, and finally highways. [666]
رشيد فهد
رشيد فهد2024-01-13 11:49
Picking up a new car and hitting the highway right away can be relatively safe as long as you follow traffic rules.
خالد تاج الدين
خالد تاج الدين2024-01-09 19:48
The new car had a bit of a smell at first, but now it's gone. You can just buy a car air freshener.
عبد العزيز أسامة
عبد العزيز أسامة2024-01-06 17:22
Bro, does your car have a plastic smell? Any unusual odors?
Hello everyone. I have an '06 Peugeot 206 with a 1.6 engine. I've been driving it for over two years now. I'm thinking about fixing it up a bit, like touching up the paint and replacing the floor mats and seat covers. I've been keeping up with the maintenance, so I won't go into that. Now I'm just wondering, given the age of the car, is it worth investing more into it? Would appreciate your advice. Thank you!
I've been considering getting a Changan CS95, but I'm worried about the high fuel consumption, which is said to be around 12-15 liters. Is it really that bad?
I just went out for a drive, and it seems like there's a problem on the way back. Is there anyone who knows about cars that can listen and tell if it's an engine issue? It's the holiday season, how should I fix it? (Mainly worried about further driving damaging the engine.) The specific situation is that on the way back, there was a noise indicating a fault, but no warning light came on. Then during two turns, the steering suddenly locked and the car stalled. Since I wasn't far from home, I drove a bit more and parked at home.
I'm driving a 2021 1.4T Comfort T-Cross, and it's run less than 20,000 miles. There have been two instances where it suddenly braked and paused while driving normally. What's the reason for this? Does anyone know?
Has anyone successfully unlocked their car system? I'm looking to modify my car's system mainly to install third-party apps like Dudu Launcher. I'm hoping to find a tutorial on how to unlock the system's permissions without fully flashing it, as my current package is a lifetime deal, and I'm worried it might void it. Any advice from knowledgeable car enthusiasts would be greatly appreciated. Thanks! 🙏
I'm driving a 2017 model 1.4T automatic 2WD luxury version. Last year, I replaced the recalled vacuum pump. When I used to drive it daily, I didn't notice any issues. Recently, I've been using the car less, and after it's been parked for a day or two, the brakes feel hard when I start it in the morning. I wanted to check if the vacuum is sufficient, so I tried coasting in neutral and after pressing the brakes a couple of times, they become hard. I want to ask fellow car owners if they've experienced the same situation. Thanks.
I can't charge my electric Lavida, thought it was a grounding issue (there's a grounding wire left by the developer in the electrical box), so I connected it to the ground as well, using two 60cm grounding rods and a 50cm grounding angle iron, but it still sometimes charges and sometimes doesn't. Even the portable charger doesn't work. It's driving me crazy. When I took it to the 4S dealership, it charged fine. They updated the car's system, but it still won't charge at home. I tried two neighbors' charging stations, but it still won't charge. What's going on? Has anyone experienced something similar? It's been over 3 years and 50,000 km.
