Hey car enthusiasts! I've got a 2018 Santana with 50,000 km on it. In winter, I'm having trouble getting it into reverse—it just goes into first gear when I push up. But if I let it idle for 10-30 minutes, I can get it into reverse. What's going on?
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
The 2019 Yuexiang has a strange noise from the belt area when starting in sub-zero winter temperatures, but it goes away after a few minutes. After inspection, no issues were found. What's going on?
4I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
5The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
6I'm considering getting a 911. How much of a discount can I expect now? The 4S is only offering 10%, and I feel that's too low.
7The car's infotainment screen goes black, but when I switch to reverse, it lights up without displaying anything. [facepalm]
8Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
9Are there any modern cars with a boxy design like the Santana? I really can't get into the streamlined shapes; they all look the same.
10Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
