نايف قادر
2024-10-01 11:06
Even with the clutch fully pressed, the car still won't start.
لبيب خالد
لبيب خالد2024-10-08 08:57
If you're really stuck, stay calm. Remove the key and wait for 1-2 minutes. Then try again. Maybe everything will be fine.
محمد عبد له
محمد عبد له2024-10-06 12:48
You need to be in neutral to start the car.
عمر نبيل
عمر نبيل2024-10-03 06:03
You need to press both the brake and the clutch simultaneously to start the car.
قنصوح عبدالله
قنصوح عبدالله2024-10-03 06:02
Battery dead? Or when you turn the key, nothing lights up on the dashboard? Also, did you make sure it's in neutral?
Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Won't start
There's a noise coming from the transmission, but when I press the clutch, it stops. The dealership said it's an issue with the clutch disc, and they've already replaced it. But the problem still isn't solved!
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
I have a 2009 Accent. Why does the car stall every time I press the clutch?
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
Is the lumbar support of the standard 14-way seats on the 992.1 unable to fully retract into the backrest? Even when adjusted all the way in, it still sticks out and presses against the lower back. It's really uncomfortable over time.
I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
