حسين عبد المجيد
2024-08-01 10:11
Does the 2017 Santana with a 1.4 engine have a loudspeaker on the passenger side? My passenger side got wet, and I'm not sure if there was a loudspeaker there originally.
عبدالله يزيد
عبدالله يزيد2024-08-10 07:05
There are two in the front, one for the driver and one for the passenger. None in the back.
The engine number for the 2008 2.5T Volvo C70 is typically located on the engine block. It's usually found on the passenger side of the engine, near where the engine and transmission meet. You might need a flashlight to see it clearly, as it can be a bit hidden. Make sure to check around the area thoroughly.
Passenger side rear footwell is mysteriously accumulating water, while the other three spots are dry. The headliner is also normal with no water stains. It's just the passenger side rear that's wet! Can anyone help me figure this out?
2009 Yaris, the cup holder on the passenger side dashboard is making noise, not sure what to do about it. Anyone got any ideas? [Crying][Crying][Crying]
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Hello everyone, does the original 2019 model come with a dashcam? I see there's a camera, but I'm not sure how to use it.
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
I found cracks at the connection part of the driver's door on my 2017 Ford Taurus, and there's also one on the passenger side. Fellow owners, is this really a crack?
What's the model of the alternator bearing for the 2016 Santana with a 1.4-liter engine? Can someone please share?
Does anyone know the original brand of loudspeaker for the Tiida? I have the 2024 model, and I'm thinking about upgrading the audio system. Has anyone done it?
