سعود ناصر
سعود ناصر
Nov 29
I just got my car two months ago, and whenever I park, the brakes cause a bit of a jolt, making my body lurch forward. Is this due to my braking technique or something with the car?
Comments( 6 )
أحمد مسعود
أحمد مسعود2024-11-30 14:34
No way, the front fork of this car is already quite stiff. If you lift your foot before the final brake stop, it won't dip forward as much. But Volvo's suspension is already very stiff. When I drive the Zeekr, the dipping is even more severe, soft like a Volkswagen.
محمد نور
محمد نور2024-11-30 10:34
When braking quickly, slightly ease off the pedal a bit.
نور الدين عمر
نور الدين عمر2024-11-30 07:04
Brake early, don't come to a sudden stop.
عبدالرحمن لهب
عبدالرحمن لهب2024-11-30 06:31
Don't step on it too hard.
محمد نور الدين
محمد نور الدين2024-11-29 23:46
Late braking, too aggressive.
خالد بندر
خالد بندر2024-11-29 23:25
The technique takes practice, but it can get a bit better with time. Still, it's hard to completely avoid some slight headaches. [I want to be alone]
When braking to a low speed, there's a metallic noise. Does anyone know what's going on??? The brake pads were just replaced two or three months ago.
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
Picked up the car less than two months ago, got rear-ended with damages estimated at 40,000. Can I make him pay for the depreciation, guys? My heart aches.
What should I do if my ES300h's battery is dead after being parked for half a month?
My car has run 50,000 kilometers, and now I notice it starts to shake when reaching speeds of 80 to 100 km/h. I've already done wheel balancing, and the throttle body was cleaned six months ago. Does anyone know how to solve this? Please help!
My car has run 50,000 kilometers, and now I notice it starts to shake when reaching speeds of 80 to 100 km/h. I've already done the wheel balancing and cleaned the throttle body six months ago. Does anyone know how to solve this? Please help.
I got my Defender 110 less than 4 months ago, and the wipers are already leaving a lot of water streaks. Has anyone else experienced this? What brand of wipers did you switch to?
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
Hello everyone! I just got my car and I'm still getting used to it. It feels big and hard to park. What is the appropriate setting for the detection distance, and will it brake automatically?
Volvo S90
Volvo S90QAR 179,900 ~ 284,000Gasoline & Petrol
