أحمد مهدي
أحمد مهدي
Nov 30
Can the front lip chrome strip be covered under warranty if it's scratched? It got bent after running over a small animal.
عبدالرحمن لهب
عبدالرحمن لهب2024-12-03 21:10
I'm not sure.
نور الدين عمر
نور الدين عمر2024-12-01 06:33
No way, either spend your own money or wait for the right person. [I want to be alone][I want to be alone][I want to be alone]
How many kilometers can a March engine typically run under normal conditions?
Is the X95 water pump not covered under the extended warranty?
The engine feels sluggish and powerless after running over 100,000 kilometers. Does anyone know the reason?
Hi everyone, the electronic steering lock of my Chery Jetour X70 is broken and needs to be replaced. The 4S shop said it's no longer under warranty, so I have to replace it myself. It seems to cost several thousand. Does anyone know if the 10-year or 200,000 km warranty indicated by the lifetime warranty badge on Jetour still covers it? The steering system is an important part of the car. The car was registered in August 2020, so it's been almost four years. Does anyone know if this is still under warranty? Please help.
The 2021-2022 model with just over 52,000 kilometers on the engine is experiencing issues, but it is not covered under warranty.
What exactly is covered under the lifetime warranty that the manufacturer claims for the Roewe RX5 MAX?
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
Hey experts, the headlight cover on my Sharan has turned yellow and has lots of small cracks. Can it be repaired, or do I need to replace the cover? Is there any place where I can buy the parts? Thanks.
Why is my car's rear shock absorber leaking oil? Is this covered under warranty?
Are you guys renewing the extended warranty? After using up the extended warranty you got when you bought the car, would you choose to continue buying it? Or would you just go to an external shop for maintenance?
Volvo S90
Volvo S90OMR 18,900 ~ 29,400Gasoline & Petrol
