نايف فخريل دين
2021-03-08 18:13
What does the activation of the immobilizer mean?
سلمان نصر
سلمان نصر2023-03-12 04:48
It's a common issue. Keep trying with the key, and sometimes you might get lucky and it will start. The main problem is likely the battery being dead. You can try jump-starting it to see if that helps. If it works after that, then it's probably the battery.
عبد العزيز رومي
عبد العزيز رومي2021-03-08 20:54
Activating the immobilizer means that your vehicle's anti-theft system is in effect, preventing the vehicle from starting. You might need an emergency start to get it going.
