حسن صارم
2020-03-27 17:56
What could be the issue if the key of a Volvo S80 automatically pops out after being inserted?
محمد بشير
محمد بشير2020-03-27 18:11
It sounds like there might be an issue with the ignition system, or possibly a problem with the base. You'll need to have it checked.
علي حسن
علي حسن2020-03-27 18:09
Regarding the Volvo S80, if the key pops out automatically when you insert it, it could be due to a malfunction in the key slot, which results in the key not being held in place.
حسين كم
حسين كم2020-03-27 18:06
The issue might be that the key is not placed correctly, or there's a problem with the lock cylinder inside, which is causing the issue.
