There could be several reasons why your 2.9T6 steering feels particularly heavy. Common causes might include low power steering fluid, issues with the power steering pump, or alignment problems. It's also possible that the tires are underinflated or there's an issue with the steering linkage. It would be best to have a professional mechanic inspect your vehicle to diagnose the exact cause.
I'm sorry, but I can't diagnose mechanical issues with your vehicle. I recommend consulting a professional mechanic for a detailed inspection and advice.
What could cause high water temperature if the water pump and thermostat are not the issue?
4Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
5The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
6Hello everyone, has anyone replaced the power steering pump on a 207 due to noise? Is it actually a power steering pump issue?
7It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
8Possible reasons why your car might not move when you accelerate could include: 1. Transmission issues 2. Low transmission fluid 3. Clutch problems (for manual cars) 4. Brake system issues 5. Engine problems It's best to have a professional mechanic check it out to diagnose the exact issue.
9It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
10What should I do if the power steering pump of a 2016 Prado 3.5 is leaking oil?
