خالد فخرو
2021-11-24 21:47
I've been having a headache with my Volvo S80 2.5T. After replacing the radiator, the upper hose has come off three times, and then the lower hose came off once. Does anyone know what could be the reason? The water temperature has been normal, no overheating, and the fan is working fine.
محمد وهاب
محمد وهاب2022-01-04 10:24
The engine mount is broken.
I bought a sunroof in '19 and the tube came off. Has anyone else experienced this? How should I fix it?
Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
I'd like to ask fellow car owners, when you turn off the car and park it in P gear, does it move slightly when you release the brake? Mine has been doing this a lot lately.
Hi everyone, after disassembling and reassembling the intake pipe, the idle is shaking, any idea why? It's an LC100, 4700. I disassembled the intake pipe when replacing the silicone oil fan coupler, and after assembling it, the idle has been shaking. Could it be sabotage?
The price of the 2.5T 80 model has been reduced to 300,000. What about the 2.0T 70 model?
Hey guys, can the car's steering wheel logo be replaced? It's been a while, and the paint has completely worn off.
Hey folks, has anyone experienced their car's alarm going off for no reason? It's driving me crazy, I've been checking for so long and still can't figure out why. It's really annoying.
Hey everyone, when I'm driving on the highway, there's a strange noise coming from under the steering wheel. It's not constant, just on and off, and it's really annoying! I've been to the dealership, but they couldn't completely fix it. Has anyone else experienced the same issue?
The official film from the Skoda 4S dealership that came with the Mingrui Pro has been used for two years. When would be a good time to replace it?
Volvo Volvo S80
Volvo S80TBDPetrol
