نايف ميمون
2023-02-20 13:16
I have a problem with the brakes on my Volvo S80L. I've replaced all the brake fluid, but it still feels like the car doesn't stop well when reversing. The pedal is hard to press. Is it a clogged brake line, or could it be something else? Can anyone help analyze this issue?
فهد عبيد
فهد عبيد2023-08-03 10:26
Brake vacuum booster
عبدالرحمن عثمان
عبدالرحمن عثمان2023-07-29 22:55
The brake caliper might be faulty.
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
I feel like the brake pedal on my Jeep Compass is both hard and high. Does anyone else notice this on their car?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
When the car starts normally and the brake pedal becomes hard after driving a certain distance, what could be the reason?
Volvo Volvo S80
Volvo S80TBDPetrol
