خالد قاسم
2023-12-24 11:16
Can the data such as water temperature and oil temperature be displayed?
What could cause high water temperature if the water pump and thermostat are not the issue?
I've never encountered an issue with high water temperature in my car. There's no water leakage. What could be the problem?
Is it true that March doesn't have a water temperature gauge?
4Where is the water temperature gauge?
5How to solve high water temperature issue in V73?
6Can the 2013 base model Touran display the outside temperature?
7Can the data such as water temperature and oil temperature be displayed?
8What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
9Where to check the water temperature gauge in a hybrid vehicle? 😂😂
10What's your water temperature?
