محمد خليل
2024-05-11 17:58
Why does my car's radiator show high temperature after driving for a while? Does anyone know the reason?
ميسور نايف
ميسور نايف2024-05-15 10:02
Clean the cooling fan and check the coolant. If it's low, top it up.
I've been having a headache with my Volvo S80 2.5T. After replacing the radiator, the upper hose has come off three times, and then the lower hose came off once. Does anyone know what could be the reason? The water temperature has been normal, no overheating, and the fan is working fine.
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
Why does the right front wheel of my 2019 GA6 get about ten degrees hotter than the other three wheels after driving for a while? When I touch the hub, the temperature difference is quite noticeable.
Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
Does anyone know if it's possible to set the default to economy mode? My fuel consumption is too high, and I want to try driving in economy mode for a while. 🤦‍♂️
Why does it show high coolant temperature at startup? Unable to start.
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
Why can't my newly purchased USB drive be read and why does it show as not connected?
