Why can't the 2016 S5 detect the USB drive, and where can an SD card be installed?
Can I plug in a USB drive? Where is the port located?
Hey friends, where do I insert the SD card in a 2012 VW Phaeton?
Where do I insert the SD card for the Vellfire's TV?
4Where is the USB port located in the Haima S5?
5Can the 2014 Sharan audio system support an SD card?
6Why can't the 2016 S5 detect the USB drive, and where can an SD card be installed?
7Why does it still prompt "no memory card" even though I put a card in the SD slot during emergency braking?
8Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
9Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
10Why can't my newly purchased USB drive be read and why does it show as not connected?
