عمر أيوبي
2021-12-14 16:06
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
نايف أسماء
نايف أسماء2024-01-21 23:33
Does it have anything to do with the light bulb???
عبدالرحمن عبد عزيز
عبدالرحمن عبد عزيز2022-01-01 13:02
Replacing the front headlights with LEDs shouldn't be an issue, right? This won't cause any problems, will it?
سهيل سعود
سهيل سعود2021-12-30 16:41
Could you please provide more context or details for the translation?
عمر أيوبي
عمر أيوبي2021-12-28 21:13
Problem solved by replacing the rear brake light with a halogen bulb. If you use an LED bulb, this issue occurs.
حسن خلدون
حسن خلدون2021-12-15 20:25
Check the brake lights. 😊
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
The manual sunroof of the Haima S5 Youth Edition can't open. The motor is functioning properly, but it's stuck and won't move.
What could be the reason for the Haima S5's warning light being on or flashing, and the lack of acceleration?
Why does the car not move when I put it in gear, but only moves when I accelerate?
My One suddenly won't move when I press the gas while in D gear today. It feels like something is dragging it. Any fellow car enthusiasts know or have encountered this situation before?
When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
