When I press the accelerator while the car is stationary, it jerks like a newbie driving a manual car. But if I let it coast a bit after releasing the brake and then press the accelerator, it runs smoothly. Does anyone know what might be causing this? ╮(╯_╰)╭
I want to ask fellow car enthusiasts, what could be the cause of a jerking sensation when pressing the accelerator?
I have a 2014 Haima S5 manual transmission, and it's not running smoothly. During acceleration, it feels jerky and there's a noticeable lag when shifting gears. What's causing this issue? Can any experienced drivers or mechanics help me out? 🙏🙏🙏🙏🙏
4Why can't the Pajero burn out when the brake is fully pressed and the accelerator is fully pressed in D gear, with the RPM only reaching a bit over 2000?
5In normal mode, when coasting after releasing the throttle, the car jerks when the speed drops to 5 KM/h. Is everyone experiencing this too?
6When I press the accelerator deeply, the car jerks, but it's fine with light acceleration. What's going on? It's a 2014 manual elite model.
7Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
8What causes a jerking sensation when gently pressing the accelerator?
9Hi fellow car enthusiasts, I have a 1.6 CVT that's been running for ten years with over 60,000 kilometers. Last month, I just did maintenance, changed the transmission fluid and spark plugs. It was running fine for the first few days, but recently it's been jerking occasionally when I lightly press the accelerator. It's similar to a manual car when you give gas without fully releasing the clutch. The engine goes "woo-woo-woo," and the whole car shakes a bit, but the speed doesn’t increase. Then, when I press the accelerator harder, it goes back to normal. Does anyone know what might be happening?
10Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
