خالد صارم
2023-11-26 10:58
What should I do if the seatbelt doesn't retract automatically?
Comments( 15 )
خالد يسار2024-10-23 23:33
Could you please provide more context or content for translation?
علي حبيب2024-08-10 22:37
When getting out of the car, just flick the latch inside with your right hand, otherwise the door won't close.
سلمان باسم2024-08-07 21:50
I just bought it not long ago, and the right window regulator is already broken. The quality control is really something else.
محمد إياس2024-08-07 12:45
This is a common issue.
ميسور نايف2024-07-12 09:30
Same here, I don't want to get it repaired. Just manually push it in, and it's fine.
عبدالله ثمين2024-03-20 14:51
I have the same issue, sometimes the door gets stuck when closing.
عاطف عمر2024-03-18 11:51
It's so simple, I fixed it. Let me tell you.
فهد لقمان2024-03-17 13:31
My 2016 model also has a seatbelt that doesn't retract.
عبدالرحمن منذر2024-03-07 13:18
Common issue, just release it by hand and let it retract slowly. [I need some quiet time]
حسن رائد2024-03-03 23:35
Common issue! Just manually retract it!
What should I do if the trunk of my 1.6 automatic car has water ingress? Is it a big issue?
What should I do if my automatic Kia Sportage stalls on the highway and won't restart?
When I start my car, the seatbelt indicator light flashes for a few seconds and then turns off automatically, even though I haven't fastened my seatbelt yet.
4Is there a seatbelt warning light? Mine doesn't have one. Does yours?
5No money to buy, what should I do?
6What should I do if there's rust inside the wheel?
7What should I do if the seatbelt doesn't retract automatically?
8What should I do if there's carbon buildup?
9What should I do if the sunroof doesn't close properly and there's always a small gap at the back?
10What should I do if there's a sudden power outage?
