What could be the reason for the Haima S5's warning light being on or flashing, and the lack of acceleration?
How to turn on the center console screen of the Haima S5 if it's not lighting up?
What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
4The 4LO warning light and the engine light on the Land Cruiser are both flashing.
5What could cause the steering to be heavy on a 2015 Haima S5 automatic?
6What could be the reason for the Haima S5's warning light being on or flashing, and the lack of acceleration?
7Hey car enthusiasts! For the 2017 MG GS 30T, if you're finding that the car lacks power when starting without using the accelerator, what could be the reason?
8What could be the reasons for not being able to shift gears?
9What could be the reasons for not being able to shift gears?
10I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
