محمد اشرف
2023-10-22 12:17
What could be the issue if the radiator fan of the Haima S5 only operates when a blower is used, and doesn't turn on even after driving for a long time?
عمر موجا بطاقة تعريف
عمر موجا بطاقة تعريف2024-05-08 11:57
The fan bearings are aging, so it's time to replace the cooling fan. Usually, it can still turn on when the air conditioning is on, but it's almost worn out.
حسن رائد
حسن رائد2024-03-03 23:46
The water temperature won't reach the cooling requirement if it doesn't turn on! It won't operate during the small circulation. Only during the large circulation, when the thermostat opens, will the electric fan start to cool.
Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
How to turn on the center console screen of the Haima S5 if it's not lighting up?
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
What could be the issue if the fan doesn't turn on at 90°C for a 2016 manual XINRUI?
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
