To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
How to reset the odometer for Haima S5?
How to reset the trip meter on Ruixing?
The air conditioning panel of the Haima S5 is flickering, but it stops flickering when the parking lights are turned on!
4To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
5Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
6How do I reset the trip meter after maintenance on a V40?
7To reset the tire pressure light on the MG GS 4WD, follow these steps: 1. **Check Tire Pressure**: Ensure all tires are inflated to the recommended pressure levels. You can usually find the recommended pressure on a sticker inside the driver's door or in the owner's manual. 2. **Drive the Car**: Sometimes, simply driving the car for a few miles can reset the tire pressure monitoring system (TPMS) if the tires are properly inflated. 3. **TPMS Reset Button**: Some models may have a TPMS reset button. Check your vehicle's manual for its location and instructions on how to use it. 4. **Professional Assistance**: If the light remains on, it might be necessary to have the system checked by a professional, as there could be an issue with the TPMS sensors. Please follow these instructions based on your specific vehicle model and refer to your owner's manual for more detailed guidance.
8To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
9How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
10Help Needed: 2011 Nissan Sunny Low-End to High-End Instrument Panel Upgrade Issue At first: As shown in the picture, I bought a 2012 luxury version of the Sunny instrument panel. I removed the wires from the low-end panel and connected them according to the high-end socket order. Because I enlarged the wire holes when removing them, it led to poor contact. Initially, everything was normal except the fuel gauge didn't display. Could it be due to poor contact? Then, I reconnected the original low-end instrument panel, which led to the time, trip mileage, and fuel consumption resetting every time I started the car. Finally, I got another high-end socket. This time, I arranged the wire order for the high-end socket first, then connected wires from the low-end socket to the high-end socket (this method avoids enlarging the socket and causing poor contact). Now I'm stuck with the following issues: 1. The engine light is on. 2. The turn signal, headlight, and fog light indicators on the instrument panel don't light up, and there's no ticking sound when using the turn signal. 3. Each time I start the car, the time, average fuel consumption, and trip mileage reset. 4. After turning off the car, the tachometer stays at 1, then drops to 0 and returns to 1 when the car is started again, which seems normal. Everything else seems normal. Could fellow forum members help analyze what the problem might be? I'm almost crying.
