The original battery in your Haima S5 from 2016, manual transmission, has been in use for six years. After being parked for half a month, you jump-started it with a power bank and have been driving it 50 kilometers daily for a week, but it still remains in a discharged state. If the car can't start after being off for more than an hour, it might be time to replace the battery.
Has anyone experienced a dead battery causing the anti-theft system to lock, and jump-starting didn't help?
4If the sunroof has been lubricated but won't close after being opened, what could be the issue?
5The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
6Is it normal for a car to lose its battery charge after being parked for a few days?? Please share your thoughts.
7What should I do if my ES300h's battery is dead after being parked for half a month?
8Looking to buy an affordable and practical external power source for jump-starting a battery. Any recommendations, guys? [pleading face]
9Does a transmission remain durable after being repaired once? If it breaks again, how long did it take before you had to repair it again? [facepalm]
10Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
