The low beam is a bit low. Which setting is appropriate to adjust it to?
The low beam is as good as nonexistent.
I feel like the high beam is aiming a bit high. Is there a switch in the car to adjust it? I've looked around but couldn't find anything.
How can I adjust the high and low beam headlights inside the car?
4How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
5Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
6How to adjust the low beam height on the GAC Trumpchi GS7?
7How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
8I replaced a pair of LED bulbs on my car, but now the low beam and high beam look the same. Any tips to adjust them to be lower?
9The low beam is a bit low. Which setting is appropriate to adjust it to?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
