The air conditioning panel of the Haima S5 is flickering, but it stops flickering when the parking lights are turned on!
How to turn on the center console screen of the Haima S5 if it's not lighting up?
What could be the reason for the Haima S5's warning light being on or flashing, and the lack of acceleration?
What could be the issue if the radiator fan of the Haima S5 only operates when a blower is used, and doesn't turn on even after driving for a long time?
4Is the 2015 Haima S5 CVT with over 90,000 kilometers on it, insurance expired, in excellent condition, worth buying for 1.98?
5Does your Santana's engine shake when you turn on the air conditioning for cold air?
6When the air conditioning is on and blowing cold, the car shakes a lot, especially when stopped at a red light. It's uncomfortable. Do any of you have this issue with your car?
7Why does the air conditioning blow cold air while driving, but not when stopped at a traffic light?
8When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
9The new Suzuki Alto stalls when the air conditioning is turned on while idling in the summer.
10I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
