عبد العزيز قابوس
2024-10-13 17:58
My car has keyless entry, but after unlocking, the car gives four alarm sounds. What's going on? This didn't happen before. It used to just unlock automatically when I got close, with the lights flashing but no sound. Now it flashes four times and gives four alarm sounds!
Why does the keyless entry only lock but not unlock the car?
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
I just got a 2013 model with a 1.4t engine, and it's been driven for 130,000 kilometers. When I use lower-grade fuel, the high-pressure fuel pump makes a buzzing sound. What could be the reason for this, experts? The sound goes away after driving for a while, but it happens right after starting the car.
Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
Does anyone know why there's a high-pitched buzzing sound inside the car as soon as it's powered on? It's been happening the last few days and it's giving me a headache.
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
