My 2018 automatic car with a turbo is losing engine oil. I've checked with the service center; there's no blue or white smoke from the exhaust, and there's no sign of oil leakage on the engine exterior. Both the oxygen sensor and spark plugs are clean. The service center couldn't find the problem. Anyone knows what might be wrong?
Does the 2012 Jeep Compass with a 2.4 engine consume oil or lose oil?
The 2023 standard version Rubicon has an issue where if it's left for two nights, the brake pedal becomes very hard in the morning when I press it to start the car. I'm wondering if anyone else has experienced this issue with their Jeep. I went to the 4S dealership, and they checked the vacuum pressure, which was at 620 and held for a morning without any signs of leakage. Is using a smoke machine the only way to check it? Sigh 😮💨
4Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
5For a 2005 1.8T Touran, what engine oil should be used for a minor service?
6Does anyone have engine oil leakage?
714 model, 1.5T, exhaust pipe doesn't emit blue smoke, but there's significant oil consumption. Can any expert shed some light on this?
8Where do you all get your cars serviced, and what kind of engine oil do you use?
9Does oil leakage from the engine hood of the 2014 Peugeot 301 affect its use?
10I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
