Is the 2016 1.6 equipped with a belt or a chain?
The 2016 1.6 manual feels really sluggish when accelerating. Does anyone else have the same issue?
Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
When should the timing belt be replaced on a 2016 Sportage with 80,000 kilometers? Experts, please advise.
4I have a 2016 Haima S5 automatic, and the belt is making noise. I've changed the water pump pulley, the crankshaft pulley, and the belt, but the noise is still there. Has anyone experienced a similar problem?
5Does the Mazda 5 use a timing chain or a belt?
6Guys, does the 2015 Mitsubishi ASX Silk Road version have a belt or chain in the transmission?
7Is the timing on the 2017 1.4T Jeep Renegade a chain or a belt?
8Is the 2013 model using a timing belt or a chain?
9Does anyone know if the oil pump drive for the 2018 35P 1.6L is a belt or a chain? Thanks!
10Is the transmission in the 2019 Murano using a steel belt or a steel chain?
