عبدالرحمن منذر
2024-02-17 20:36
I was driving a Haima S5 1.6 CAT Creative Edition on the highway for about 6 hours, and suddenly the car couldn't accelerate. After stopping and turning off the engine for a while, it could accelerate again. What could be the problem? This has happened twice already, once on the highway before and once this year. When it couldn't accelerate, the car showed a fault code, but after parking overnight, the fault code disappeared. Has anyone else experienced this?
Comments( 7 )
سلمان باسم
سلمان باسم2024-08-07 21:49
I also experienced a sudden loss of power while overtaking at about 130 km/h on the highway, and it reported a transmission fault.
محمد إياس
محمد إياس2024-08-07 12:53
I also encountered this yesterday. It was fine after an hour of stopping.
عبدالرحمن منذر
عبدالرحمن منذر2024-03-07 13:17
After replacing the throttle body assembly, the problem still persists. It seems like it might be the transmission's high-temperature protection.
حسن رائد
حسن رائد2024-03-03 23:37
Transmission Overheat Protection!
عبدالله ق
عبدالله ق2024-02-26 23:00
Brake light switch, mine's manual. Sometimes when I press the accelerator, there's no response, but if I press it again, it works. Replaced it, and now it's fine.
محمد اشرف
محمد اشرف2024-02-22 22:46
I also have a 2016 model, it might be due to high temperature.
عبدالرحمن كم
عبدالرحمن كم2024-02-18 21:41
My RPM goes up, but the speed doesn't increase. It's really hard to go beyond 80 km/h.
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
After the power reset of the Coaster, the fault code light is on and it can't accelerate. What's going on? Can any expert advise, please?
Why does the transmission often show a fault code and then disappear on its own shortly after?
What could be the reason for the Haima S5's warning light being on or flashing, and the lack of acceleration?
Engine shows fault code, acceleration is weak, what could be the reason?
What could cause a loud banging sound when I shift gears after the car has been parked overnight?
When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
