سلمان علياء
2023-01-02 13:48
I left my car for 4 days and now it won't start again. 😎😎 I'm really fed up. Where on earth is it leaking electricity? 😢😢😢😢
Comments( 6 )
حسن آسيا
حسن آسيا2023-05-25 18:13
If you're not afraid of some hassle and spending money, you can take your car to a repair shop for a thorough check. Alternatively, you might consider buying an emergency jump starter online for around 100.
نايف صعب
نايف صعب2023-05-25 15:05
I stopped for a month and a half during the pandemic and it was fine [I want some peace].
شجاع فهد
شجاع فهد2023-05-17 01:23
The same [I need some quiet time].
سعود باسل
سعود باسل2023-03-26 23:59
The reason the car lights burn out is that the lamp chamber is too small to dissipate heat, which is a common issue. It's better to switch to xenon lights as they are more resistant to high temperatures. I initially replaced the driver's side with LED lights, but they still burned out.
سلمان علياء
سلمان علياء2023-01-04 11:14
That's really frustrating.
سعود منذر
سعود منذر2023-01-04 10:53
Common issues with Haima cars, I've changed countless headlights, not sure where the electrical connection problem is.
Do air locks really tend to leak? Maybe switching to an electric lock would be more stable. What do fellow car enthusiasts think?
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
I have an 18-year-old car, and I just switched to an electric car this April. I've tried twice, and if I park for more than 5 days, it won't start. I suspect there's a power leak in the car. Has anyone else experienced this?
My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
The sunroof of my 2017 MG ZS won't open, and there's also a leak inside the car. 😢😢😢😢
Hey guys, my Levante's trunk lifts up just a bit (2cm) and then stops. If I manually lift it a bit more (5cm) and then use the key, it works again. It's really frustrating because the door is super heavy. Hoping someone knowledgeable can help me out. 😢
Hey folks, the left turn signal on my 2020 180V Automatic UP isn't working, and the dashboard blinks really fast. What should I do?
The air conditioning was set to level 4, but there was still barely any cold air and the airflow was very weak. What's going on? After a day, it went back to normal. It's really frustrating.
The engine warning light is on, indicating an oil leak. I changed the oil 4 days ago using 5-30w. What's going on? Does anyone know?
