سلمان طلحة
2024-09-30 14:13
I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
عبدالله قنصوح
عبدالله قنصوح2024-10-08 16:43
I have the same issue. The light sometimes turns on when parked, but goes off when I press the brake. Occasionally, it lights up while driving, but there are no other problems. When I went to the shop, the light wasn't on, and they said they need it to be on to check. How did you eventually solve it? 😎
محمد اشرف
محمد اشرف2024-10-06 14:57
My taillight was broken, but after replacing it, it works fine now.
How do I set the automatic locking feature on a 2016 Haima S5?
Is the handbrake of your Haima S5 working well? Mine hasn't been working properly since I bought it.
The air conditioning panel of the Haima S5 is flickering, but it stops flickering when the parking lights are turned on!
How do I adjust the average fuel consumption on a 2018 Haima S5 1.5T manual?
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
What's causing the noise when accelerating in a 2015 S5 with manual transmission, when the RPM doesn't match?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
