Are the navigation head units of the 2016 and 2018 Haima S5 compatible with each other?
How do I set the automatic locking feature on a 2016 Haima S5?
Does the 2016 Haima S5 have a locking feature?
How do I navigate the menu on a 2016 top-spec Haima with automatic transmission? It's not a touchscreen, and I couldn't find anything online. The manual is confusing. Any advice? [Facepalm]
4What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
5I have a 2016 Haima S5 automatic, and the belt is making noise. I've changed the water pump pulley, the crankshaft pulley, and the belt, but the noise is still there. Has anyone experienced a similar problem?
6Is the 2015-2016 Haima S5 automatic suitable for daily home use? Does it have many minor issues?
7Are the navigation head units of the 2016 and 2018 Haima S5 compatible with each other?
8How do I adjust the average fuel consumption on a 2018 Haima S5 1.5T manual?
9How to set the automatic door lock feature on the 2016 Haima S5?
10My 2018 Mitsubishi ASX suddenly has an issue with the multifunction buttons on the steering wheel. When I press the next track button, it switches to the previous track. Pressing the previous track button takes me to navigation or the radio. I replaced the Android head unit three weeks ago, and everything was working fine after the replacement. The issue just started today. I'm not sure if it has anything to do with the new head unit. Does anyone know how to fix this?
