14 model, 1.5T, exhaust pipe doesn't emit blue smoke, but there's significant oil consumption. Can any expert shed some light on this?
Can anyone share a picture of the mid-section exhaust pipe for a 2015 GT with a 1.5T engine? Thanks!!!
How's the 2021 Ford F-150 XLT? It seems less luxurious compared to the Laramie Longhorn, but it's not lacking in features either. It doesn't seem inferior to the F-150 Platinum, plus it has all-terrain (AT) tires. Can any expert shed some light?
What is the real energy consumption of the Model S 100D Long Range version? How many kWh per 100 km? Please share some images! I currently own a Model 3 Long Range with an energy consumption of 12.4 kWh per 100 km. I'm planning to buy a new Model S. Any advice from experts would be appreciated, mainly considering range and comfort!
4If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
5Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
614 model, 1.5T, exhaust pipe doesn't emit blue smoke, but there's significant oil consumption. Can any expert shed some light on this?
7When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
8Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
9Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
10I need some guidance from the experts. I'm new to cars and currently, my family doesn't own one. My husband works nearby, but I commute 40 kilometers to the suburbs for work every day. We live in an old neighborhood without home charging facilities, and I'm thinking of buying a new energy vehicle. I've had my license for six years but haven't driven much. I liked the appearance of the Zeekr X but heard the rear space is small. Personally, I like Zeekr and Ora, and I'm also considering Deepal. I'm really confused and don't know which car to buy. Any advice from the experts would be appreciated.
