فهد لبيب
2021-07-29 14:07
Why is there water pooling only in the rear passenger seat area, while the roof and other seats are dry, with no water stains?
علي ابراهيم
علي ابراهيم2024-03-06 06:04
Check if the drainage hole is blocked.
حسن أبشير
حسن أبشير2023-12-18 12:41
I have the same issue with my car. The air conditioning sometimes works inconsistently, being cold at times and not at others. Once, I noticed that the trash and waste paper next to the air conditioning vent under the seat were completely wet, and there was a puddle of water under the foam. After closely inspecting the roof and finding no leaks, I deduced that the air conditioning drain might be blocked, causing the water to seep out.
خالد علي
خالد علي2022-01-08 22:17
My car's air conditioning is having the same issue.
أحمد صادق
أحمد صادق2021-07-30 10:06
Sunroof leaking water
Passenger side rear footwell is mysteriously accumulating water, while the other three spots are dry. The headliner is also normal with no water stains. It's just the passenger side rear that's wet! Can anyone help me figure this out?
Is there water in the front passenger seat area? Could it be that the air conditioning drain is clogged?
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
Is it reasonable for the 4S shop to charge 500 RMB to disassemble and dry the area under the seats due to blocked sunroof drainage while still under warranty?
What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
Why do some of the new Prado models have a rear spoiler while others don't?
Why is the middle of the rear seat in the GV70 so raised?
Why are there water droplets in the spare tire area of the trunk?
Volvo Volvo S40
Volvo S40TBDPetrol
