Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
The Koleos accelerator pedal feels too soft. Can it be adjusted to be firmer? It's hard for a beginner to control the throttle.
2015 Subaru Outback with 50,000 km, the brake feels very hard when starting the car, but it's normal after starting. What could be the reason?
The suspension adjustment on the Phaeton works well in just one mode, but when switched to other modes like Comfort or Sport, the soft and hard adjustment light stays on.
4What should I do if the brakes on my Maxus T60 feel soft?
5Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
6Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
7Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
8I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
9When the car starts normally and the brake pedal becomes hard after driving a certain distance, what could be the reason?
10Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
