نايف عبد الوهاب
2024-04-06 10:32
My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
Why is the plastic near the gear lever on the passenger side very hot?
Can the footwell lights of the RDX for both the driver and passenger sides be adjusted to be brighter?
Volvo Volvo S40
Volvo S40TBDPetrol
