سعود زبير
2021-03-13 11:25
The dashboard shows a headlight malfunction. How can I fix this? Has anyone encountered this before? Please advise.
عبد العزيز رضوان
عبد العزيز رضوان2021-10-11 23:53
The wiring inside the headlight has aged. Taking it apart and rewrapping the wiring solved the problem.
عبد العزيز رمضان
عبد العزيز رمضان2021-06-01 00:44
Disconnect the battery for a minute and then reconnect it, and it disappears.
عبدالله أشرف
عبدالله أشرف2021-05-13 00:08
I'm an S40 owner. Today, I just encountered this fault warning. I believe it's a false alarm for my car. I got out and checked all the headlights, and they were functioning properly. After turning off the vehicle and starting it again, the dashboard fault warning disappeared. For your reference.
علي أنيس
علي أنيس2021-03-13 14:52
The headlight malfunction warning indicates there's an issue with the headlights. The warning light will remain on until the problem is fixed. Simply clearing the fault code won't solve the issue; the key is to repair the malfunction.
Hey folks, my headlights work during the day but not at night. Has anyone encountered this issue before? Help needed!
Can the original Bluetooth play music? Does anyone know how to connect it? Please advise.
Dear fellow car enthusiasts, my Kaiyi X3's dashboard is showing a yellow triangle with an exclamation mark inside. Has anyone encountered this? What might be the issue?
Has anyone encountered noise from the door check strap hinge? Lubrication didn't help. Can it be fixed by myself?
The cigarette lighter in the central armrest box and the trunk has no power. Please advise.
Hey guys, my car is showing error code P048013, which is about fan 1 control circuit, general electrical fault, open circuit. Has anyone encountered this error code before? Thanks.
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
Can the 2.0T Rui Shang be fitted with 20-inch wheels? Has anyone done it before? Please reply, thank you 🙏🙏🙏
Has anyone with a HS7 encountered a camera malfunction where it shows a "cannot connect to camera" message?
After replacing the battery on a 2017 Skoda Octavia 1.6 manual with low trim, the trip mileage, average fuel consumption, and other information on the dashboard reset to zero every time I lock the car for about 2 hours and then start it again. Has anyone encountered this issue or knows how to fix it? Please let me know. Thanks.
Volvo Volvo S40
Volvo S40TBDPetrol
