The car has power, but it doesn't start when you try to ignite. What could be the cause, and where should I start checking?
My 2007 S40 has power throughout the car, but there's no response when I try to start it. I'm not sure what the problem is.
What could be causing starting difficulties, where sometimes it takes two or three attempts to start?
4Even with power in the battery, my Jinxuan manual sometimes doesn't respond when starting. After turning it on and off a few times, it starts. Does anyone know what might be causing this?
5I have a 2016 Honda City, and sometimes it doesn't start on the first try, but it starts on the second attempt. Experts, what could be the problem?
6When starting the car, the battery has power but the engine doesn't respond.
7Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
8Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
9The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
10If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
