The air conditioning filter in the S40 is typically located behind the glove box. To replace it, you generally need to follow these steps: 1. Open the glove box and empty its contents. 2. Gently unhook the glove box to allow it to drop down further, giving you access to the filter compartment. 3. Locate the air conditioning filter cover, which is often held in place by clips or screws. 4. Remove the cover to access the filter. 5. Take out the old filter and insert the new one, ensuring it is positioned correctly according to the airflow direction indicated on the filter. 6. Reattach the cover, secure the glove box back in place, and close it. Always refer to the vehicle's manual for specific instructions, as the process can vary slightly depending on the model year.
The air conditioning filter in the Accent is typically located behind the glove compartment.
How to replace the air conditioning filter?
4The air conditioning filter for a 2013 Liana is typically located behind the glove compartment. You may need to remove or lower the glove compartment to access it.
5Hi everyone! Does anyone know how to replace the air conditioning filter for the 2019 model? How to remove the glove box on the passenger side? If you know, please let me know. Thanks!
6How to replace the air conditioning filter?
7Can anyone teach me how to change the air conditioning filter? I can't remove the glove box.
8The air conditioning filter for the 2011 Volvo S40 is typically located behind the glove compartment. To access it, you usually need to open the glove compartment and remove any screws or clips that hold the compartment in place. Once removed, you should be able to see the air filter housing and replace the filter.
9Where is the air conditioning switch function located?
10How do I remove the glove box? I want to replace the air filter myself.
