فهد لبيب
2021-07-29 10:10
Passenger side rear footwell is mysteriously accumulating water, while the other three spots are dry. The headliner is also normal with no water stains. It's just the passenger side rear that's wet! Can anyone help me figure this out?
عمر فادي
عمر فادي2021-09-20 09:06
I had the same issue. The reason was the sunroof water pipe. The water pipe near the dashboard came loose. You can see the sunroof water pipe by removing the trim panel inside the A-pillar.
فهد زياد
فهد زياد2021-08-24 16:59
The sunroof drain pipe is blocked, a common issue.
علي يعقوب
علي يعقوب2021-08-06 16:58
Check the air conditioning drainage.
Why is there water pooling only in the rear passenger seat area, while the roof and other seats are dry, with no water stains?
Does anyone else have a noise issue with their sunroof? My 2018 car has a serious noise problem at the rear on the passenger side. 🤦‍♂️🤦‍♂️🤦‍♂️
Why does the seatbelt alarm keep going off even though there's no one sitting in my passenger seat? Can anyone help me figure this out?
Have you experienced a situation where the welcome light on the driver's side doesn't light up, but the other three doors do?
There is sound only from the front speakers, no sound from the rear and no bass. Can anyone help me figure out what's wrong?
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
Does the 2017 Santana with a 1.4 engine have a loudspeaker on the passenger side? My passenger side got wet, and I'm not sure if there was a loudspeaker there originally.
How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
Volvo Volvo S40
Volvo S40TBDPetrol
