علي أحمد
2022-12-14 12:44
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
حسن خلوق
حسن خلوق2022-12-14 21:50
Use a computer to match the steering angle sensor.
Has anyone experienced the voice control button on the steering wheel not working, and being unable to make calls after connecting the phone via Bluetooth? The repair shop's computer test shows a microphone fault code. How can I fix this? Thanks, experts!
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
Why does the steering wheel vibrate while driving?
Volvo Volvo S40
Volvo S40TBDPetrol
