محمد راضي
2020-06-29 18:00
My 06 S40's air conditioning sometimes doesn't cool. It has refrigerant, and sometimes it works. The technician said it might be an electrical issue, while others say it could be a problem with the AC motor. Could anyone help me figure out what's wrong?
سلمان زيد دين
سلمان زيد دين2021-11-05 13:34
It's possible that adding too much refrigerant could also cause this issue.
أحمد جبريل
أحمد جبريل2021-10-19 16:53
I also had this problem and spent over 6000 to fix it. It's really expensive.
عبد العزيز رضوان
عبد العزيز رضوان2021-10-12 00:12
The compressor is broken.
حسين أم
حسين أم2020-09-11 21:23
My pressure pump head is split in half [laughing and crying emoji]
علي أنيس
علي أنيس2020-06-29 19:07
If this issue occurs, it's likely not a problem with the refrigerant. If it were due to a lack of refrigerant, the cooling effect wouldn't be intermittent. Personally, I tend to agree with the technician that it might be an electrical circuit problem, or possibly a compressor malfunction, which could also cause this situation.
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
Toyota Yizhi, the air conditioning sometimes cools and sometimes doesn't. Pressing the AC button doesn't seem to help. Not sure what's going on.
Hey everyone, I've got an issue with my new Beidouxing. When I slow down, it just stops moving even though the engine is still running. The gear lever feels loose, and I can't accelerate. The power windows should go down gradually, but instead, they drop all the way down uncontrollably. The mechanic couldn't figure it out either. Could anyone help analyze what's wrong? Thanks!
I've noticed a "pop" sound coming from the front of the car when it's cold. Once I start driving, everything seems normal. The dealership said they'd need to keep the car there to check it. Has anyone experienced a similar issue? What could be wrong? It's happened multiple times already.
Hello everyone, my Peugeot 307's air conditioning isn't cooling, but sometimes after restarting, it cools again. What could generally be the problem?
I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
Today, I saw a Land Rover Defender and thought it looked really cool. I chatted with the owner for a bit and mentioned that it looks similar to the Tank 300. The owner said that this car could buy 20 Tank 300s. Is that true?
Volvo Volvo S40
Volvo S40TBDPetrol
