خالد علي
2021-08-26 19:17
Is the engine noise of your S40 loud? When my throttle reaches 2500 RPM, I can hear the engine being quite loud, so I'm hesitant to press the accelerator hard due to the noise.
عبد العزيز رضوان
عبد العزيز رضوان2021-10-11 23:29
Adding some soundproofing might help a bit.
محمد أرسلان
محمد أرسلان2021-09-10 09:20
I changed the engine mounts and added soundproofing to the front fender. The problem is solved.
نايف دل
نايف دل2021-09-01 19:34
I'm driving a manual transmission, do you think that's a big deal?
فهد فايز
فهد فايز2021-08-29 23:39
Me too, it feels pretty normal 😂
حسن حازم
حسن حازم2021-08-28 09:13
Yes, especially when accelerating out of the garage.
Hi everyone, is the electric current noise inside the McLaren GT really loud? I test drove it the other day, and at first, I didn't hear it, but later as I sat in the passenger seat, I seemed to hear a bit. I've seen many people say the noise is quite loud and can't be fixed... I'm a bit OCD, and constant noise would drive me crazy. I'm now hesitating about buying this car.
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
Is the engine noise loud on the 2017 automatic model?
Do you also hear noise from the engine while inside the car?
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
Is the engine noise loud?
Hey car enthusiasts, after parking and turning off the engine, without opening the door, I can hear a loud electric current noise from the dashboard/center console. Have any of you experienced this?
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
Volvo Volvo S40
Volvo S40TBDgasoline
